RosCard Climate Card Guide
Configure the RosCard Climate Card to manage your HVAC and climate entities directly from your Astrion Remote. Control temperature, HVAC modes, fan speed, and swing settings.
The RosCard Climate Card provides a dedicated interface for controlling HVAC and climate entities from your Astrion Remote. It supports temperature adjustment, HVAC mode selection (Heat, Cool, Dry, Fan-only, Auto), fan speed control, and swing control[reference:0].
💡 Tip: Enable Independent Display for any Climate Card you want to appear as a full-screen, dedicated view on your Astrion Remote — perfect for room-by-room climate control.
Temperature Control
Adjust target temperature with presets: 16°, 18°, 20°, 22°, 24°, 26°, 28°, 30°C
HVAC Modes
Switch between Heat, Cool, Dry, Fan-only, and Auto modes
Fan Speed
Control fan speed: Low, Medium, High, and Auto
Swing Control
Toggle swing mode for directional air flow
Real-Time Status
Display current temperature, HVAC mode, and fan speed
2 Add Climate Card
Click Add Card and search for "AC (ROS)" or "custom:aiks-climate-card". Select it to add the card to your dashboard.
3 Configure Climate Entity
Add your climate entity to the card. The Climate Card works with any Home Assistant
climate entity that supports the standard climate.set_temperature service.
Example Configuration:
4 Enable Independent Display
For any card you want to appear as a full-screen view on your Astrion Remote, enable Independent Display. This is particularly useful for room-specific climate control.
⚠️ Important: The Climate Card requires the climate entity to support
the standard climate.set_temperature service[reference:1]. If your integration uses
a non-standard implementation (like some custom ESPHome configurations), the card may
not function correctly.
- entity_id — The Home Assistant entity ID for the climate device (e.g.,
climate.living_room_ac). - uuid — A unique identifier for the card. Generated automatically when you add the card.
- independent_display — When
true, the card appears as a full-screen dedicated view on the remote. - alias — A custom display name shown on the remote instead of the entity ID.
- icon_path — Path to a custom icon image in the Home Assistant
/local/directory.
Temperature Presets
The Climate Card provides a temperature grid with presets: 16°, 18°, 20°, 22°, 24°, 26°, 28°, 30°C. Tap any preset to set the target temperature instantly.
HVAC Modes
- Heat — Heating mode
- Cool — Cooling mode
- Dry — Dehumidification mode
- Fan-only — Fan only, no heating or cooling
- Auto — Automatically switches between Heat and Cool
💡 Tip: Fan speed buttons (Low, Medium, High, Auto) will be grayed out if the climate entity doesn't support fan speed control. Swing control is available when the entity supports the swing mode attribute.
Climate Card Not Showing on Astrion Remote
- Refresh the remote: Pull down from the top of the home screen and tap Refresh.
- Verify entity exists: Make sure the climate entity is available in Home Assistant.
- Check YAML format: Ensure your configuration uses the correct syntax and indentation.
- Update RosCard: If you're running an older version, update RosCard via HACS.
Temperature Controls Not Responding
- Check entity status: Verify the climate entity is available and not unavailable in Home Assistant.
- Test in Home Assistant: Try controlling the climate device directly from the Home Assistant UI to rule out connection issues.
- Verify service support: Ensure the climate entity supports the
climate.set_temperatureservice[reference:2]. - Rebind entities: If the card was working before and stopped, try removing and re-adding the entity.
Fan Speed or Swing Controls Grayed Out
- These controls are only available if the climate entity supports the fan speed and swing mode attributes.
- Check the entity's supported features in Home Assistant Developer Tools.
- Some integrations (like generic thermostat) may not support fan speed or swing control.
Independent Display Not Working
- Ensure
independent_displayis set totruefor the specific entity. - Only one card with
independent_display: truewill show as the dedicated view per dashboard. - Refresh the remote after saving changes.
🔧 Note: After updating RosCard to a new version, you may need to resave all your Climate Cards to refresh the binding. This is a known requirement for version updates.
Need help with Climate Card?
