RosCard Statistics Card Guide
Configure the RosCard Statistics Card to monitor and track device status directly from your Astrion Remote. Get real-time counts of active lights, switches, and climate devices in any zone or room.
The RosCard Statistics Card provides a dedicated monitoring interface for tracking device status on your Astrion Remote. Unlike other RosCard cards that control devices, the Statistics Card is designed to monitor and display the state of multiple devices in a single view.
The Statistics Card supports tracking of Lights, Switches, and Climate devices, displaying real-time counts of active devices in any zone or room. It's perfect for getting a quick overview of your smart home's status.
💡 Tip: The Statistics Card is read-only — it displays device states but does not allow toggling. For device control, use the dedicated Light Card, Switch Card, or Climate Card.
Light Monitoring
Track active and inactive light states in any zone
Switch Monitoring
Monitor switch and relay states
Climate Monitoring
Track HVAC mode and state per zone
Real-Time Counts
Instant visibility into active devices per category
Independent Display
Full-screen dedicated view for quick status checks
2 Add Statistics Card
Click Add Card and search for "Statistics (ROS)" or "custom:aiks-switch-monitor-card". Select it to add the card to your dashboard.
3 Configure Device Types
Enable the device types you want to monitor. The Statistics Card supports Light, Switch, and Climate devices.
Example Configuration:
4 Configure Monitor Name
The monitor_name parameter allows you to label your statistics view
— for example, "Living Room", "Bedroom", or "Home".
5 Enable Independent Display
For any card you want to appear as a full-screen view on your Astrion Remote, enable Independent Display.
6 Save and Refresh
⚠️ Important: The Statistics Card only monitors devices from the same Home Assistant instance. Ensure your Astrion Remote is properly connected to Home Assistant for accurate status updates.
- uuid — A unique identifier for the card. Generated automatically when you add the card.
- monitor_name — A custom name for the statistics view (e.g., "Living Room", "Home").
- device_types — Enable or disable monitoring for each device type.
Monitoring Device Types
- Light (light): Tracks all
lightentities in Home Assistant. - Switch (switch): Tracks all
switchentities in Home Assistant. - Climate (climate): Tracks all
climateentities in Home Assistant.
💡 Tip: The Statistics Card automatically counts devices by state — for lights and switches, it shows the number of devices that are on vs. off. For climate devices, it shows the number of devices in heating, cooling, or idle mode.
Example Use Cases
Room Status Overview
Get a quick status overview of your living room — how many lights are on, which switches are active, and whether the climate system is running.
Entire Home Dashboard
Monitor your entire home's status at a glance. Perfect as a home screen card on your Astrion Remote.
Energy-Aware Zone Monitoring
Monitor lights and switches only in your office, tracking energy usage and ensuring devices aren't left on unnecessarily.
Statistics Card Not Showing on Astrion Remote
- Refresh the remote: Pull down from the top of the home screen and tap Refresh.
- Verify card configuration: Ensure the YAML configuration is valid and saved.
- Check entity types: Make sure you have at least one entity of the enabled device types in Home Assistant.
- Update RosCard: If you're running an older version, update RosCard via HACS.
No Data Displayed
- Verify entities exist: Ensure you have lights, switches, or climate entities in Home Assistant.
- Check device_types: Verify the correct device types are enabled in your configuration.
- Wait for update: The card may take a moment to populate data after initial configuration.
- Restart Home Assistant: If issues persist, try restarting Home Assistant.
Incorrect Device Counts
- Verify that the entities in Home Assistant are correctly categorized as
light,switch, orclimate. - Check for duplicate or hidden entities that may affect counts.
- Refresh the card view on your Astrion Remote.
Climate Data Not Showing
- Ensure
climate: trueis set in your configuration. - Verify you have climate entities in Home Assistant.
- Check that your climate entities are reporting state correctly in Home Assistant Developer Tools.
🔧 Note: After updating RosCard to a new version, you may need to resave your Statistics Card to refresh the binding. This is a known requirement for version updates.
Need help with Statistics Card?
