Astrion Scene Card Guide | RosCard Scene Configuration for Home Assist Astrion Scene Card Guide | RosCard Scene & Script Configuration for Home Assistant
The RosCard Scene Card provides a dedicated interface for triggering Home Assistant scenes and scripts from your Astrion Remote. It supports three execution modes — Immediate, Delayed, and Popup — giving you flexible control over how your automations are activated.[reference:1]
Scene Cards are ideal for creating one-touch automation workflows like "Movie Mode", "Good Night", "Morning Routine", or any other scene you've defined in Home Assistant.
💡 Tip: Starting from Astrion firmware V1.1.1, Scene Cards have been renamed to "Scenes & Scripts" and now support script entities in addition to scenes.
Scene Triggering
Activate any Home Assistant scene with a single tap
Script Support
Trigger Home Assistant scripts for complex automation workflows
Immediate Mode
Execute scenes instantly with a single tap
Delayed Mode
Set a delay before scene execution — perfect for "leave home" scenarios
Popup Mode
Display a confirmation dialog before executing the scene
Execution Modes
The Scene Card supports three execution modes, allowing you to control how scenes and scripts are triggered from your Astrion Remote.[reference:2]
Immediate
Executes the scene or script instantly when you tap the card.
Best for: Quick actions like toggling lights or activating a scene.
Delayed
Waits for a specified delay before executing the scene or script.
Best for: "Leaving home" scenarios where you need time to exit.
Popup
Displays a confirmation dialog on your Astrion Remote before executing.
Best for: Critical actions like "Arm Security" or "Factory Reset".
2 Add Scene Card
Click Add Card and search for "Scene (ROS)" or "custom:aiks-scene-card". Select it to add the card to your dashboard.
3 Configure Scene or Script Entity
Add your scene or script entity to the card. The Scene Card works with any Home Assistant scene or script entity.
Scene Configuration:
type: custom:aiks-scene-card entities: - entity_id: scene.movie_mode uuid: 21ef9622-8e69-4736-aa1e-b505868a6a00 mode: immediate alias: "Movie Mode"
Script Configuration (Firmware V1.1.1+):
type: custom:aiks-scene-card entities: - entity_id: script.good_night uuid: 3d43a7c3-1957-4bcf-a34c-911aac62189d mode: delayed alias: "Good Night" delay: 30
4 Select Execution Mode
Choose the execution mode for your Scene Card:
  • immediate — Executes instantly when tapped
  • delayed — Executes after a specified delay (in seconds)
  • popup — Shows a confirmation dialog before executing
⚠️ Important: Starting from firmware V1.1.1, Scene Cards have been renamed to "Scenes & Scripts" and now support script entities in addition to scenes. If you're running an older firmware version, update your Astrion Remote via OTA to access script support.
type: custom:aiks-scene-card entities: - entity_id: scene.entity_id # Required: Home Assistant scene or script uuid: string # Required: Unique identifier mode: immediate | delayed | popup # Execution mode alias: "Custom Name" # Display name on remote delay: 30 # Delay in seconds (for delayed mode)
  • entity_id — The Home Assistant entity ID for the scene (e.g., scene.movie_mode) or script (e.g., script.good_night).
  • uuid — A unique identifier for the card. Generated automatically when you add the card.
  • mode — Execution mode: immediate, delayed, or popup. Defaults to immediate.
  • alias — A custom display name shown on the remote instead of the entity ID.
  • delay — Delay in seconds before executing (only used when mode: delayed).
Execution Modes
  • immediate — The scene or script runs instantly when the card is tapped.
  • delayed — The scene or script runs after the specified delay. Ideal for giving you time to leave the room or home.
  • popup — A confirmation dialog appears on the remote before execution. Perfect for critical actions.
Example Use Cases
Movie Mode (Immediate)
type: custom:aiks-scene-card entities: - entity_id: scene.movie_mode uuid: 21ef9622-8e69-4736-aa1e-b505868a6a00 mode: immediate alias: "🎬 Movie Mode"
Tap to instantly dim lights, close blinds, and switch the TV to the correct input.
Good Night (Delayed)
type: custom:aiks-scene-card entities: - entity_id: script.good_night uuid: 3d43a7c3-1957-4bcf-a34c-911aac62189d mode: delayed alias: "🌙 Good Night" delay: 30
Tap, then walk to bed. After 30 seconds, lights turn off, doors lock, and the alarm sets.
Arm Security (Popup)
type: custom:aiks-scene-card entities: - entity_id: script.arm_security uuid: 8fd848c5-78a1-41dc-bbf7-43b965bfe463 mode: popup alias: "🔒 Arm Security"
Tap to display a confirmation dialog before arming the security system — preventing accidental triggers.
Scene Card Not Showing on Astrion Remote
  • Refresh the remote: Pull down from the top of the home screen and tap Refresh.
  • Verify entity exists: Make sure the scene or script entity is available in Home Assistant.
  • Check YAML format: Ensure your configuration uses the correct syntax and indentation.
  • Update RosCard: If you're running an older version, update RosCard via HACS.
Scene Not Triggering
  • Check entity status: Verify the scene or script is available in Home Assistant.
  • Test in Home Assistant: Try triggering the scene or script directly from the Home Assistant UI to rule out connection issues.
  • Verify script exists: If using a script, ensure the script ID is correct and the script is enabled.
  • Check script mode: If the script is in single mode, it won't trigger while already running.
Delay Not Working
  • Ensure mode: delayed is set correctly in your configuration.
  • Verify the delay value is specified in seconds (e.g., delay: 30 for 30 seconds).
  • Check that your firmware version supports delayed execution (V1.1.1+ recommended).
Popup Not Showing
  • Ensure mode: popup is set correctly in your configuration.
  • Verify that your firmware version supports popup mode (V1.1.1+ recommended).
  • Check that the remote's screen is active when triggering the card.
🔧 Note: After updating RosCard to a new version, you may need to resave all your Scene Cards to refresh the binding. This is a known requirement for version updates.
Need help with Scene Card?
← Back to TV Card Guide Next: Activities Guide →
