Why Astrion Voice Control is Different
Astrion does not replace Home Assistant Assist — it extends it.
Most smart home voice assistants create another ecosystem. Astrion takes a different approach. The remote does not add a new voice assistant, a new AI, or a new account. Instead, it becomes a natural voice endpoint for the Home Assistant Assist you already have.
- One Home Assistant brain
- Multiple voice endpoints
- Same AI conversation agent
- Same automations and scenes
Astrion remotes can invoke the voice assistant configured in Home Assistant, but they do not provide built-in voice services. You must complete the HA Assist configuration first.
Step 1: Configure Home Assistant Assist
If you already have Assist configured, you can skip to Step 2. To add a new one:
- In Home Assistant, go to Settings → Voice assistants and click Add assistant.
- Configure the required components (all three are mandatory):
| Configuration Item | Required? | Purpose |
| Name | Custom | Used to identify the current voice assistant. |
| Conversation agent | Required | Understands user intent and generates dialogue replies. |
| Speech-to-text | Required | Converts spoken voice into text. |
| Text-to-speech | Required | Converts reply text into spoken voice. |
Step 2: How to Use Voice on Astrion
No extra configuration is needed on the remote. Once paired with HA, simply:
Press the Voice Button
Located on the side of the remote. (Note: Astrion does not support hands-free wake words).
Long-press and Speak
Hold the button while speaking. Release it when you are done.
Listen & Return
The response plays through the built-in speaker. The interface will not close automatically; press the Back button to return.
Real-World Feedback
Tried the voice assistant button on the remote. Zero extra setup and is directly hooked to my Home Assistant Voice Assistant, using the same voice and AI. Just hold the button and speak. The sound comes back through the remote's speaker.
Technical Features
Push-to-Talk
Press to start listening, release to send. Natural and intuitive.
Your Existing Pipeline
Uses your configured speech pipeline — Whisper, HA Cloud, etc.
Built-in Speaker
Spoken responses play back through the remote's speaker.
Shared Configuration
Inherits your voice assistant, AI agent, automations, and entities.
Voice not working properly?
- Confirm that the voice assistant has been saved in HA.
- Ensure that the Conversation agent, Speech-to-text, and Text-to-speech are all configured.
- Check if the assistant invoked by the remote is the fully configured Assist.
- Ensure your Astrion Remote is paired with Home Assistant and the server is accessible.
- Check the volume level on the remote, and ensure it is not muted.
Visit the Community Forum for help from other Astrion users and the development team.
