Astrion Remote Setup Guide | Home Assistant Integration & RosCard Astrion Remote Setup Guide | Home Assistant Integration
Video Overview
Watch this complete walkthrough of the Astrion Remote setup process with Home Assistant.
📌 Prefer written instructions? Follow the step-by-step guide below. Each section includes links to relevant video chapters for visual reference.
Additional Video Resources
If you're new to the Astrion Remote, this video covers the essential steps you shouldn't skip — from unboxing to first-time configuration.
New
First Time With Astrion Remote?
Don't skip these steps — a complete walkthrough for first-time users.
Watch on YouTube →
More video guides coming soon
💡 New to Astrion? We recommend watching the beginner's guide first, then following the detailed setup steps below for a smooth experience.
High-Level Workflow
Setting up your Astrion Remote with Home Assistant involves seven main steps. Here's the big picture before we dive into the details:
  1. Prepare Home Assistant — Ensure your devices are integrated and working
  2. Install Integration & Dashboard — Add Astrion and RosCard via HACS
  3. Create a Dashboard — Build a Lovelace dashboard with RosCard cards
  4. Connect the Remote — Pair your Astrion Remote with Home Assistant
  5. Sync the Dashboard — Pull the dashboard data to your remote
  6. Configure Physical Buttons — Map hardware buttons to actions
  7. Fine-Tune and Update — Keep everything up to date
✅ New to Astrion? The latest v1.4.0 release introduces custom physical button mapping and improved device discovery stability.[reference:0] Make sure you're running the latest version for the best experience.
Step 1 — Prepare Home Assistant
Before you begin, make sure your Home Assistant instance is ready for the Astrion Remote.
Prerequisites
  • Home Assistant running version 2024.12 or newer
  • HACS (Home Assistant Community Store) installed
  • Your devices (lights, climate, media players, etc.) already integrated and working in Home Assistant
  • Your Home Assistant instance is accessible from the Astrion Remote (same network or via secure remote access)
💡 Tip: If you're new to Home Assistant, we recommend starting with the official getting started guide before proceeding with the Astrion setup.
Step 2 — Install Integration & Dashboard
The Astrion Remote requires two components installed via HACS: the integration (for device communication) and the RosCard dashboard (for the remote's UI).
2.1 — Add the Integration Repository
1 Open HACS
In Home Assistant, navigate to HACS → Integrations.
2 Add Custom Repository
Click the menu (⋮) → Custom repositories → Add.
  • Repository URL: https://github.com/yyqclhy/Astrion-integration
  • Category: Integration
Click Add to save.
3 Install the Integration
Search for Astrion Home Integration in HACS, click Download, and restart Home Assistant when prompted.[reference:1]
2.2 — Add the RosCard Dashboard Repository
1 Open HACS → Dashboards
Navigate to HACS → Dashboards.
  • Repository URL: https://github.com/yyqclhy/RosCard
  • Category: Dashboard
Click Add to save.
3 Install RosCard
Search for RosCard in HACS Dashboards, click Download, and refresh the frontend.
✅ Version 1.4.0 Update: Both the Astrion Remote system and RosCard integration have been updated to v1.4.0. Please ensure both are updated for full compatibility.[reference:2]
Step 3 — Create a Dashboard for Astrion
Create a dedicated Lovelace dashboard for your Astrion Remote. This dashboard will contain the RosCard cards that appear on your remote.
1 Create a New Dashboard
In Home Assistant, go to Lovelace → Dashboards and click Add Dashboard. Name it something like "Astrion Remote".
2 Add RosCard Cards
In your new dashboard, add RosCard cards for the entities you want to control:
  • Light — control brightness, color, and scenes
  • Curtain / Blind — open, close, set position
  • Fan — speed control and on/off
  • Climate / AC — temperature, mode, fan speed
  • Media Player — play/pause, volume, source selection
  • Scenes — trigger automations and scenes
  • TV — power, input, volume, direction keys
  • Weather — current conditions and forecast
3 Configure Each Card
For each RosCard:
  • Select the corresponding Home Assistant entity
  • Optionally set display aliases for cleaner naming
  • Enable "independent display" for quick-access pages
4 Organize into Views
Organize cards into views (rooms or modes) if you want multiple pages on the remote. For example:
  • View 1: "Living Room" — lights, TV, climate
  • View 2: "Bedroom" — lights, blinds, fan
  • View 3: "Media" — media players, scenes
💡 Tip: The remote will display cards in the order they appear in your dashboard. Arrange them strategically for the best user experience.
Step 4 — Connect the Astrion Remote
Now it's time to connect your physical Astrion Remote to Home Assistant.
1 Open Astrion Settings
On your Astrion Remote, open the Settings app and navigate to the Home Assistant or Integration section.
2 Enter Connection Details
Enter your Home Assistant connection details:
  • Instance URL: Your Home Assistant URL (e.g., http://homeassistant.local:8123)
  • Access Token: A long-lived access token generated in Home Assistant
To generate a token: In Home Assistant, go to Profile → Security → Long-Lived Access Tokens → Create Token.
3 Pair the Remote
The Astrion Home Integration should auto-discover your remote[reference:3]. Follow the on-screen prompts to complete the pairing and linking process.
⚠️ Troubleshooting: If the remote is not discovered, ensure both devices are on the same network. The integration uses mDNS for discovery — check that your network allows multicast traffic.[reference:4]
Step 5 — Sync the Dashboard
Once your remote is connected, sync your RosCard dashboard to the device.
1 Open the Astrion App
On your Astrion Remote, open the main app or launcher.
2 Use the Sync Function
Look for the Remotios / Sync function in the app or settings. This pulls the RosCard dashboard data from Home Assistant.
3 Verify the Sync
After sync, your remote should display your custom cards and be able to control the linked entities. Test a few buttons to confirm everything works.
💡 Tip: If you make changes to your dashboard in Home Assistant, you'll need to re-sync the remote to see the updates.
Step 6 — Configure Physical Buttons
Starting with v1.4.0, you can map up to 8 custom physical buttons on the TV card.[reference:5] This allows you to fully customize hardware button behavior per device context.
6.1 — Select Remote Model
1 Open TV Card Settings
In Home Assistant, open your TV Card configuration.
2 Select Your Remote Model
In the TV Card settings, select your Astrion remote model. This defines which physical buttons are available for mapping.[reference:6]
Find your model: Astrion App → Settings → About[reference:7]
6.2 — Configure Button Behavior
1 Open Shortcut Configuration
In the TV Card's shortcut configuration page, you can map physical buttons to actions like play/pause, scene triggers, light toggles, and more.[reference:8]
2 Understand Global Button Behavior
The Global Button Behavior setting controls how physical buttons behave:
  • Enabled — Uses global shortcut mapping everywhere[reference:9]
  • Disabled — Uses TV card mapping inside TV screen, global mapping elsewhere[reference:10]
When disabled:
  • Inside the TV interface → physical buttons follow ROS TV card mappings[reference:11]
  • Outside TV interface → buttons follow global shortcut settings[reference:12]
3 Map Each Button
For each physical button on your remote:
  • Direction keys (Up/Down/Left/Right)
  • Power button
  • Volume keys
  • Colored shortcut keys
Assign actions like:
  • Play/pause media
  • Trigger scenes
  • Toggle lights
  • Change inputs
  • Run automations
✅ v1.4.0 Feature: Custom physical button mapping is now available for all Astrion Remote models. Update both the firmware and RosCard to v1.4.0 for full compatibility.[reference:13]
Step 7 — Fine-Tune and Update
Keep your Astrion Remote and RosCard integration up to date for the best stability and access to new features.
Keeping Everything Updated
  • Astrion Firmware: Updates are delivered over-the-air (OTA). Check for updates in Settings → About.[reference:14]
  • RosCard Integration: Updates are available via HACS. Check HACS for new versions.[reference:15]
  • Current Version: Both the Astrion Remote system and RosCard are at v1.4.0 as of July 3, 2026.[reference:16]
Making Changes to Your Dashboard
  • Adjust card layouts, scenes, and automations in Home Assistant
  • Re-sync the remote to apply changes
  • Test your configuration after each change
Reporting Issues
  • If you experience any issues after an update, please report them in the official support thread[reference:17]
  • Include your firmware version, RosCard version, and a description of the issue
📌 Community-Driven Development: Sanytron actively iterates based on real Home Assistant usage scenarios.[reference:18] Your feedback helps shape future updates.
What You Can Control
Once configured, your Astrion Remote can control a wide range of devices and services integrated with Home Assistant:
Lights & Switches
On/off, brightness, color, scenes
Curtains & Blinds
Open, close, set position
Fans
Speed control, on/off
Climate / AC
Temperature, mode, fan speed
Media Players
Play/pause, volume, source
TV & IR Devices
Power, input, volume, direction
Scenes & Automations
Trigger routines with one press
Weather & Info
Current conditions, forecasts
💡 Need a tailored setup? If you tell us your exact remote model and what you want to control first (e.g., lights + TV), we can outline a minimal, step-by-step config tailored to that setup.
Related Resources
Need help with setup?
Our support team and the Home Assistant community are here to assist you.
← Infrared Control Guide Next: Bluetooth Support →
