Checklist
20 min total
6 steps
Final step
Astrion Remote Setup Checklist
Track your progress through the complete Astrion Remote HA100 setup process. Check off each step as you complete it — from unboxing to Home Assistant pairing.
Setup progress
0%
Complete Setup Checklist
Follow these steps in order to get your Astrion Remote up and running. Click the checkbox next to each step to mark it as complete.
Open your package and verify all contents: Astrion Remote, Magnetic Charging Dock,
USB Charging Cable, User Manual, and Certificate of Conformity.
Place the remote on the magnetic charging dock. Allow 2-3 hours for a full charge.
Check the LED indicator — solid red means charging, solid green means complete.
Press and hold the side power button for 3-5 seconds until the screen activates.
Explore the Astrion Launcher interface and settings menu.
Go to Settings → Network → Wi-Fi. Select your network, enter the password,
and verify the connection. Supports 2.4GHz and 5GHz bands.
Install RosCard via HACS, create a Long-Lived Access Token, generate a QR code,
and scan it on your Astrion Remote. Alternatively, use manual login.
6. Verify & Explore
Confirm your RosCard views are loading correctly. Explore the dashboard,
configure shortcut buttons, and start controlling your smart home devices.
Need help with setup?
