ASTRION SERIES · SUPPORT GUIDE
Sensors & Automations
Unlock the full potential of your Astrion remote. Use its built-in sensors and voice assistant entities to trigger powerful Home Assistant automations.
Prerequisites
Before you begin, ensure you have completed the following:
- Astrion Home Integration: Installed via HACS and paired with your remote.
Astrion Home Repo: https://github.com/yyqclhy/Astrion-integration - Voice Assistant: Go to Settings → Voice assistants in HA and configure an assistant.
- Speaker / TTS: Install Microsoft Edge TTS via HACS and ensure the service is configured in Home Assistant.
Available Entities & Sensors
Once the device is added, you can view these entities in Home Assistant. Note that entity names may vary slightly depending on the integration version.
| Entity / Function | Status / Purpose | Automation Use Case |
| Screen Brightness | Read or adjust remote screen brightness | Directly controllable in integration |
| Speaker | Volume control | Depends on configured TTS / speaker service |
| Wake & Sleep | Wake screen or turn off screen | Can trigger automation events |
| Battery | 0 - 100% | Trigger automations based on numeric state |
| Charging | Charging / Not Charging | Trigger automation when charging state changes |
| Screen State | On / Off | Use for state conditions |
| Motion Event | Pick up / Put down events | Excellent for triggering automations when the remote is lifted |
| Voice Assistant | Voice assistant entities/actions | Use for TTS notifications and announcements |
Example: Low Battery Voice Alert
This example triggers an automation when the remote's battery is low, then broadcasts a reminder via Voice Assistant or Edge TTS.
Step 1: Set the Trigger
- Create an automation in Home Assistant and search for your Astrion remote.
- Add a trigger, select the Battery entity, and choose Numeric state.
- Set the threshold. A common practice is to set it below 20%.
Method A: Voice Assistant Announcement
In the "Then do" (Actions) section, add a Voice Assistant announcement. The configured assistant will speak the text directly.
- Search for and select Announce on satellite under Voice Assistant.
- Enable the Message field and enter the text to be announced (e.g., "Remote battery is low, please charge.").
- Click Run/Execute to test and confirm the voice assistant announces correctly.
Method B: Microsoft Edge TTS
If you prefer to announce through the remote's Media Player entity, call the Edge TTS Service's Speak action.
- In "Then do", search for TTS and select Edge TTS Service → Speak.
- In the entity selector, choose your remote's Media Player entity (if you have multiple, identify by name).
- Enter the text to be spoken and click Run/Execute to test.
After a successful test, save the automation and give it a recognizable name, such as "Remote Low Battery Alert".
Advanced: Dock Smart Plug Automation
If your dock is connected to a smart plug that supports Home Assistant automation, you can manage charging based on the battery state to avoid keeping it at 100% or draining it completely.
- Place the remote on the dock after use.
- When Battery drops below 10%, turn ON the smart plug to charge.
- When Battery rises above 95%, turn OFF the smart plug.
Example: Control Music with Motion Event
The Motion Event entity can trigger automations based on specific actions. This example uses the "Pick up" event to control music playback.
- Create an automation, search for the Motion Event entity under your Astrion remote, and choose Event received as the trigger type.
- From the event list, select Pick up.
- In the "Then do" section, select the music player or playback action you want to control.
- Save and name the automation. Test by picking up the remote to confirm the music action triggers as expected.
- You can map different actions (like "Pick up" or "Put down") to different home automations.
- Before creating the automation, verify that the Motion Event entity reports events correctly and that the trigger action matches the actual operation.
Summary
By using the Battery, Charging, Screen, and Motion Event entities provided by the Astrion Home integration, you can combine notifications, media players, and smart plugs to build daily automations that fit your lifestyle.
