ASTRION PRO · EXCLUSIVE FEATURE
HA Native Dashboard (Lovelace Mode)
Discover how to load Home Assistant's native Lovelace dashboards directly on your Astrion Pro, and master the specialized navigation rules.
Configure HA Native View
- In Home Assistant, open Edit Dashboard, and create a new view or edit an existing one.
- Set the view name (e.g., "Demo"). At the end of the URL path, append the suffix
--astrion-web. This suffix triggers the WebView mode on the APK. - Save the view. On your Astrion Pro, pull down to refresh and switch to the newly configured view to enter HA native Lovelace mode.
If your original path is
demo, change it to demo--astrion-web.If there is no other URL path content, you can just enter
--astrion-web.
Remote Operation Rules in Lovelace Mode
View Switching
When entering a Lovelace view, the focus defaults to the current dashboard name. Press the OK button to open the view switching page.
Directional & Home Keys
In Home Assistant native Lovelace views, the directional keys are not used to navigate HA interface elements by default. The behavior depends on the current interface:
| Current Interface | Directional / Home Key Behavior |
| HA Native View, HA Device Details, or Dropdowns | No effect (No physical navigation) |
| ROS View | Functions normally |
| ROS Device Details | Functions normally |
| Settings Screen | Functions normally |
Global Shortcuts & List Keys
- Global shortcut keys still function within the Lovelace page (behavior depends on your remote settings). This includes jumping to the device interface and view interface.
- The List key (Room switching) continues to function in Lovelace mode.
- The Home key defaults to the rules in the table above, but it can still be configured in settings to jump to the Home screen.
Device Details & Fallback Mechanism
In Lovelace mode, the remote determines which device details page to open based on the card type:
| Card Type | Remote Jump Target |
| ROS Card | Astrion's ROS secondary device details interface |
| HA Native Card | Home Assistant native details interface |
When ROS Card Details Fail to Open
If jumping to the ROS card details fails, the remote will display a lightweight prompt: "Device status abnormal, jumping to HA native interface", and will automatically open the HA native details page.
| Reason for Failure | Explanation |
| Remote not connected to HA | Unable to retrieve HA or ROS card information. |
| Device missing locally on remote | Device may not be refreshed, or local device list is incomplete. |
| Device doesn't support details | The device has no jumpable ROS details interface. |
Troubleshooting Tips
- Confirm Astrion Pro is connected to Home Assistant, and refresh the device list on the remote.
- Verify if the current card type and local device match the devices in HA.
- If the device has no ROS secondary details page, you can use the automatic fallback to open the HA native details page.
